Constituent Name, full (more than first line) Action Notes, and date of note
I am trying to produce a report with:
Constituent Name
Action Type (phone call, etc)
Action Note (I can get the first line but no more)
Date of Note
Tech support says it cannot be done and I have put a suggestion in to RE.
Any ideas greatly appreciated.
  • I do this all the time through export or query export.
    Are you pulling Action Note - Note or Action Note - Description?
    Are you getting the single line in the Export or on the query results?
  • Melanie Freimuth:
    Constituent Name
    Date of Note
    Hi Melanie,
    Are you trying to do this with a canned report?  If so I doubt you can do that and tech support is correct
    But if you export as Shani suggested it should work.  There is a character limit in the notepad within Excel (I believe it is the standard 255/265 characters). So if it is a long note it will truncate.
    Once you export the data, if you know how to use Crystal Reports you can set up a report based on the data so it looks nicer than an Excel listing
    Good luck!
    Joanne
  • Melanie Freimuth:
    Constituent Name
    Date of Note
    The canned reports for Actions are really limited and not designed well.  Your best bet is to pull a query through Export for Action info, especially if you are including notes
