Event Registration
Can a person signing up for an event add a comment or note?  Is there a section in the Event Registration that allows for that?
  • The closest thing that comes to mind is Participant Attributes. When creating/editing the form, this option is found on the second tab, Field Options. Note that you will first need to add the Participant Attribute to the Configuration Tables in RE: before they will be accessible here. When adding it to the table, you can set the Data Type to text. Not sure what the character limit is for this, but after adding this to RE: and then adding it to your form via Field Options, it should result in a text field that the would-be registrant can type in.
    It's a little complicated, and another downside is that this data will be buried on Participant records when you first process the transaction. You can always move it once you've captured it.
