Partitions interface
So I've found multiple places in the documentation that refer to a "Partition Management" tab under Data Management > Import/Export, but I don't have any such tab in my interface. I'm not sure if I'm missing something obvious, if I'm looking at documentation that isn't in sync with the product, or if this is something that's part of some module I don't have. (And related to that, is there any doucumentation of which modules provide which specific bits of UI? I've run into this several times where I can't find UI that is referred to in the docs or was available on the training servers, and I'm not even certainimp which module which I don't have that provides it.)
I don't see any 'Partition Management' under Data Sync either. I wonder if this is one of those things that Convio must turn on for you. Sometimes these also turn out to be Convio only areas.
Please post if you find out the answer!
Regards, BPM
Brian Mucha:
Regards, BPM
Ok, figured it out.
Partitions only seem to be available if you have web services enabled, which was not the default in my case, so does require a talk with your account manager and/or support. As soon as I got them up, the partitions tab shows up where the docs say it will.
