New Release To The Raiser's Edge/Luminate Online Integration Available
A new release to the Raiser's Edge/Luminate Online integration is now available on the Download section of our website! Please note the version update to the Luminate Online plug-in for The Raiser's Edge to version 1.4.5963.37112 and Blackbaud Web Services to version 1.4.16120.1. With this release, you can set Luminate Online fund limits and update primary contact information imported from Luminate Online.
Luminate Online Fund Limits Option
A new Settings option has been added to the Luminate Online Options screen accessed from RE > Luminate Online > Options pop-up. This option allows you to set a fund limit between 501 – 10,000. The default limit in the Fund limit field is set to “0.” This default setting points the application to the Webservices Web configuration file first. If a value is set in Webservices, it is used; if no value is set in Webservices, the application sets the default to 500.
Should you enter a value not allowed, 1 - 500 or greater than 10,000, a warning screen appears. Clicking OK on the warning screen reverts the limit back to the previous valid value and closes the Luminate Online Options screen.
Upload Import Corrections through Service Bus
When errors are encountered during Raiser Edge to Luminate Online imports, Blackbaud's customer support team remedies the errors externally and then provides users the corrected external document. Once you receive the document from Blackbaud, you can import it into your system to complete the Raiser's Edge to Luminate Online import. You must be logged into Raiser's Edge with the Supervisor user account.
Upload RE to LO import corrections from Blackbaud
  1. Save the Blackbaud-provided file locally.
  2. Go to Liminate Online > Options pop-up > Tools.
  3. Click Open, and map to the Blackbaud file you saved locally.
  4. Click Open.
  5. The file imports and automatically corrects the Raiser's Edge files that failed to import and then moves those files into Luminate Online.
Webinars
If you haven’t already, be sure to take advantage of this FREE training and informational webinars for the Raiser’s Edge/Luminate Online integration! We offer 4 free webinars that cover what to do before integrating, how to work with the integration, troubleshooting issues with the integration, as well as best practices for data management with the integration.
To sign up, check out this link today!
