Trouble with cross-domain API calls
Hi all,
I'm trying to create an offsite form using 40Nuggets that dumps into Luminate online. I copied this code from a splash page we're using on our main page and it works fine, but now I'm getting this error message:
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at https://secure2.convio.net/comcau/site/CRConsAPI?luminateExtend=1.7.1&api_key=COMCAU_API_KEY&method=getLoginUrl&response_format=json&v=1.0. (Reason: CORS header 'Access-Control-Allow-Origin' missing).
Here's the code in question. Any idea how I could fix this? I've heard from BB support that Noah Cooper might be able to help out.
(function($) {
                var cb_surveyForm = $('.cb-lo-survey')
                        , cb_step1 = $('.cb-step1')
                        , cb_step2 = $('.cb-step2');
                $.fn.displayErrorMessage = function(message) {
                    $(this).removeErrorMessage().prepend('<div class="cb-errors"><div>' +
                            (message === undefined ? '<b>Please make sure you have provided a valid value for highlighted fields.</b>' : message) +
                            '</div></div>');
                    return this;
                $.fn.removeErrorMessage = function() {
                    $(this).find('.cb-errors').remove();
                    return this;
                $.fn.submitLoading = function() {
                    $(this).bind('submit', function() {
                        $(this).before('<div class="cb-loading">Please wait ...</div>').hide();
                    return this;
                $.fn.bindLuminateForm = function(options) {
                    var settings = $.extend({
                        onBeforeLuminateExtendSubmit: $.noop,
                        customFormValidation: function() {
                            return [];
                    }, options || {});
                    $(this).unbind('submit').bind('submit', function(e) {
                        var hasErrors = false, errMessages = [];
                        $(this).find('.required').each(function() {
                            var fieldName = $(this).attr('name');
                            $(this).removeClass('error');
                            $('label[for="' + fieldName + '"]').removeClass('error');
                            if ($(this).attr('type') === 'radio') {
                                if (!$('input[name="' + fieldName + '"]:checked').val()) {
                                    $('label[for="' + fieldName + '"]').addClass('error');
                                    hasErrors = true;
                            } else {
                                var fieldValue = $.trim($(this).val());
                                if (fieldValue === '') {
                                    $(this).addClass('error');
                                    hasErrors = true;
                        var customValidationErrors = luminateExtend.utils.ensureArray(settings.customFormValidation());
                        if (customValidationErrors.length > 0) {
                            hasErrors = true;
                            errMessages.push(customValidationErrors);
                        if (hasErrors) {
                            var errorsList = $('<ul></ul>');
                            if (errMessages.length > 0) {
                                if (errMessages.length > 1) {
                                    for (var i = 0; i < errMessages.length; i++) {
                                        errorsList.append($('<li class="text-danger">' + errMessages[i] + '</li>'));
                                } else {
                                    errorsList.append($('<li class="text-danger">' + errMessages[0] + '</li>'));
                            $(this).displayErrorMessage().find('.cb-errors').append($('<p></p>').append(errorsList).html());
                        } else {
                            settings.onBeforeLuminateExtendSubmit();
                            $(this).unbind('submit').submitLoading();
                            luminateExtend.api.bind();
                            $(this).submit();
                        e.preventDefault();
                    return this;
                window.surveyCallback = {
                    error: function(data) {
                        cb_surveyForm.displayErrorMessage(data.errorResponse.message);
                        cb_step1.find('.cb-loading').remove();
                        cb_surveyForm.show();
                    success: function(data) {
                        cb_surveyForm.removeErrorMessage().find('.cb-loading').remove();
                        if (data.submitSurveyResponse.success == 'false') {
                            cb_surveyForm.displayErrorMessage('');
                            var surveyErrors = luminateExtend.utils.ensureArray(data.submitSurveyResponse.errors);
                            $.each(surveyErrors, function() {
                                if (this.errorField) {
                                    $('input[name="' + this.errorField + '"]').addClass('error');
                                    cb_surveyForm.find('.cb-errors').append('<div>' + this.errorMessage + '</div>');
                        else {
                            try {
                                setCookie("subscribed", "true", 365);
                            } catch (err) {
                            cb_surveyForm.unbind('submit');
                            cb_step1.hide();
                            cb_step2.show();
                            // Google Analytic
                            addGoogleAnalyticsEvent('survey: ' + cb_surveyForm.find('input[name="survey_id"]').val(), window.location.href);
                function addGoogleAnalyticsEvent(action, label) {
                    if (typeof (dataLayer) === "object") {
                        dataLayer.push({'event': '40Nuggets', 'fnAction': action, 'fnLabel': label});
                    if (typeof (ga) === "function") {
                        ga('send', 'event', '40nuggets', action, label);
                    } else if (typeof (_gaq) === "object") {
                        _gaq.push(['_trackEvent', '40nuggets', action, label]);
                function cb_init() {
                    luminateExtend({
                        apiKey: 'COMCAU_API_KEY',
                        path: {
                            nonsecure: 'http://act.commoncause.org/site/',
                            secure: 'https://secure2.convio.net/comcau/site/'
                    cb_surveyForm.attr('action', luminateExtend.global.path.secure + 'CRSurveyAPI').bindLuminateForm();
                    $('input[name="cons_email"]').bind("keyup blur", function() {
                        $('.cb-fn-email').val($(this).val());
                if (typeof luminateExtend == 'undefined') {
                    $.getScript('//cdnjs.cloudflare.com/ajax/libs/luminateExtend/1.7.1/luminateExtend.min.js', function() {
                        cb_init();
                } else {
                    cb_init();
            })(jQuery);
  • That error message indicates that you've not whitelisted the domain you're making the API call from. See https://github.com/noahcooper/luminateExtend:
    For security reasons, the API and this library limit requests to a list of domains whitelisted by your organization. If you haven't already done so, go to Setup -> Site Options -> Open API Configuration, and click "Edit Javascript/Flash configuration". For the purposes of using this library, the only options you need to worry about on this page are 1. Allow JavaScript/Flash API from these domains and 2. Trust JavaScript/Flash API from these domains. Add any domains where you will use this library to these lists. As noted on the page, you can use an asterisk as a wildcard if your website has multiple subdomains, e.g. "*.myorganization.com"
  • Wow, I feel silly. I added it to the whitelist before I reached out to BB support, but mispelled my own domain name. Thanks for the quick response and help, Noah!
