blog implementation: image as content item rendering with black border; suggestions?
ello,
We created a new "blog" content type, which contains an "image" SelectList property.
The SelectList pulls a set of content items based on an image-only folder in our WSM.
I want one of the list display templates to call that "image" field, and to display the image, linking to the URL of the "blog" content item. The image is appearing and linking, however, it is rendering with a black border. I have tried adding inline CSS to specify no border in the <a> tag but it is not working.
Is there a way to control the border of an image when it is used as a content item?
(Prior to this, when we called a word-limited excerpt of the body for the list template, the image in the <<body>> field automatically appeared in the list template. However, we want to go with a separate <<description>> field for the list template, and therefore need the option for an image select (that is borderless) in the list template.
Any suggestions?
Thank you!
Rachel Hassinger
Rachel,
There are two ways that you can address your problem:
- Add style in your css file for image and assign it border to be none. Ex: .blog img {border: none}, to set border to 0 for all images on your site img {border: none} will do the trick
- Update the source of your list template to look something like this <a href="${url}"><t:list id="name-of-image-field"><img src="${url}" alt="${name-of-alt-text-field}" border="0" /></t:list></a>
Sincerely,
Elizabeth
Elizabeth M:
Rachel,
Sincerely,
Elizabeth
Thank you, Elizabeth!
