Can I change the label of a field in the transaction summary 120 stag?
I see a whole bunch of possibilities in the Mess Catalog. I just searched All Products on 'Tax'.
Try s120tag:dc_taxDeductibleValue
If none do the trick you can always rebuild the transaction summary manually with html and S-Tags.2 -
What you're looking for the Message Catalog is "ar_taxdeduct_value"
If you search for "Tax-deductible" - that will drastically cut down on the volume of results.
Cheers,
Sara2 -
Thank you both! Both options worked perfectly!0
