Pagewrapper help
Hi!
Anyone know where to change the pagewrapper for Personal Pages so that they match the event page pagewrapper?  Thanks!
Cassandra
Animal Welfare Association
  • I think the public facing Personal Pages should always use the pagewrapper from the event. I don't recall any way to change that.
    The participant facing 'back end' of the participant center (PC2) uses a different system. Select "Step 12. Customize Pages" and you will see a Related Actions section hiding towards the bottom of the left side. There you should find the Edit Participant Center Wrapper and Preview Participant Center links.
    The PC Wrapper is a lot less powerful than a normal page wrapper. You are pretty much limited to adding a masthead.
    Regards, Brian
