Welcome Series
Hi,
Using the same welcome series campaign, I reedit the welcome series by using the "Return to Draft" and continue to update the message.  I also set the recurring delivery I think it was the same as before. I want this message to go to new registers only.  Can someone check the message and see if I have the delivery setting right?  Many thanks for your time.
Randy Pope
American Association of the Deaf-Blind
  • Hi Randy,
    I took a quick look and it appears that everything is set up correctly.  If you see any problems in the coming weeks, don't hesitate to post back with follow-up questions, but you should be all set.
    Hope you're doing well!
    -patrick
