Conditional test returns "Failed to evaluate expression null:null"
Hello,
I'm writing a display template for a News content type. The News content type has a photo_1 field, which is a drop-down menu that allows the user to pick an item of the Image content type to go with the article. The field photo_1 is optional. Additionally, the Image content type has been modified to include a field called "credit", which is also optional (it's the name of the photographer).
In my display template for News, I can successfully test whether the optional photo_1 has been set by using:
<t:if test="photo_1.length > 0">photo_1 has been set.</t:if>
However, I'd like to reference the "credit" field of photo_1 in my News template. I figured that, since I can use the dot notation above to reference the length of photo_1, then I'd be able to use the same notation to reference the "credit" field of photo_1 The following tests to see if "credit" was filled in all fail:
<t:if test="photo_1.credit.length > 0">the credit for photo_1 has been set.</t:if>
<t:if test="photo_1.credit != null">the credit for photo_1 has been set.</t:if>
<t:if test="!isNull(photo_1.credit)">the credit for photo_1 has been set.</t:if>
Each of them renders the following message in the browser: "Failed to evaluate expression null:null"
Please note that I'm running the tests above INSIDE the <t:if> block that tests "photo_1.length > 0", so that I know I have a valid photo_1 before I reference it's "credit" property.
Does anyone know how I can correctly check for a valid "credit" for the photo_1 Image item that's part of my News content type definition?
Thanks in advance!
Yep! Whenever you have an object or item of a second content type linked to a primary CT, you need to use the t:list id parameter, like so:
<t:list id="photo_1"><t:if test="!isNull(credit)">the credit for photo_1 has been set.</t:if></t:list>
Or:
<t:list id="photo_1"><t:if test="credit.length > 0">the credit for photo_1 has been set.</t:if></t:list>
All variables inside the t:list block refer to the photo_1 item and not the main item. Another way to do this would be to create a display template for your image CT that would handle this, and use a standard CMS list to insert it with the correct DT.
Silvio,
If credit field is just a text fields testing for length will always fail. Length test only applies to category-based fields or fields that link to another item of a specific content type in your site.
The syntax corrections Jim made are accurate. Here's a code that you might find helpful.This tests if photo_1 field is not null & then prints out the div around the image, sets the width of that div to the width of the image & then prints the credit field if it is not null.
<t:list id="photo_1"><div class="my-photo-box" style="${imagewidth}"><img src="${url}" alt="${alt_txt}" />
<t:if test="!isNull(credit)">${credit}</t:if>
</div></t:list>
</t:if>
Elizabeth M:
Silvio,
</div></t:list>
</t:if>
Thank you everyone for your help. I followed your recommendations and now everything is working fine!
Elizabeth M:
Silvio,
</div></t:list>
</t:if>
How is that imagewidth variable nowhere in the documentation?? *runs off to update half a dozen display templates that have been broken for a year*
Jim Drey:
Jim,
The imagewidth & imageheight variables are recent additions to the product, you can find the updated documentation of templating language here.
