Tribute Gifts
We are setting up a new donation form and are trying to select the option "Include the tribute gift option".
The form says "to enable tribute gifts, you must set up the Honor/Memorial Tracking module to track tribute information."
Where can we find this module?
  • Honor/memorial tracking is an option module called RE: Tribute. It sounds like you may not be currently subscribed based on the message you are getting. The module allows you to record all gifts made in honor or memory of individuals, properly acknowledge donors, and inform the honoree or designated family members of each contributor and what he or she gave. I highly recommend it!
  • Do you have the Tribute module?  (If you do, there will be a constituent tab of "Honor-Memorial" when you open a constituent record.)  If you don't have it, then you will need to link the field that you're currently using to track Honorariums/Memorials (likely a gift attribute) to the giving form.
  • Christine Robertson:
    I see the Honor-Memorial tab, when I opened a constituent record, however, the form still does not pull up any tribute types to include.
