Thermometer for donation count goal?
Has anyone put a thermometer on a LO donation form (not in TeamRaiser) to show the number of donations on that form compared to a goal? Is this possible? Any examples and tips are welcome!
thanks very much,
Gaby Gollub
World Wildlife Fund
thanks very much,
Gaby Gollub
World Wildlife Fund
You can do gift amount using the Campaign thermos, just put the form in it's own campaign. I can't think of a way to do it for donation count though. There isn't an S-Tag or API call to get that as far as I know.0
We do this a lot to show progress to goal, however I'm not sure how to add an actual donation count. Just make sure to put the donation form(s) in the same campaign, and then use the "Component Type" to insert a progress meter. It's very basic, but it works! Here's a sample of what we've done: http://www.bethematchfoundation.org/site/Donation2?df_id=13735&mfc_pref=T&13735.donation=form11
Nice.
Kerrie, I see you use the Checking payment option. Do you find many people using that?0 -
Thanks for your responses! And thanks for sharing that form, Kerrie. That's awesome.
The thermometer I'm hoping to create is pretty similar to what's on this form:
https://secure.nokidhungry.org/site/Donation2?df_id=13805&13805.donation=form1
I see the JS behind this but I don't see where the actual count of members/donors is coming from. Any ideas?
Thanks for your help,
Gaby0 -
I'm guessing this is using a group, and the S450 tag - which was revealed in this thread:
https://community.blackbaud.com/forums/viewtopic/3/5193?post_id=5193#p5193
On each donation tier you can configure a group to add the donor to. Just set all the tiers to add to the same group, you can then use the 450 tag to return the count.
BUT. The use of the word 'members' is telling. If someone donates twice, they will still only be a member of the group once. So you aren't really reporting on 'donations', but rather on unique donors.
Another issue with this approach is that the number returned is cached and will only be accurate when the group is rebuilt (or Refresh Summary is clicked on the Group Information tab.) The most an automatic rebuild can happen is once a day, I believe.
NOTE: I don't think you could make this group rebuildable directly. But you CAN make a rebuildable group using Query. Just define that rebuildable group as All Members of the form's donor group. (The rebuildable group is just a 'mirror' of the donor group.)4 -
Thanks for sharing all of this. I'm not sure I follow it all but I will do some exploring and see what I can do!
Any more tips are welcome.
Gaby0 -
Brian Mucha:
Nice.
Kerrie, I see you use the Checking payment option. Do you find many people using that?Not really. At this point, it's only about 4-5% of our total gifts. We are in the process or re-evaluating it now, and also adding PayPal as an option..
Wow, 5% is not that bad. Considering the drop-off with expired card numbers that 5% could add up over time.
Do what Brian mentioned: # of Donations: [[S450:group#:COUNT]] - the count rebuilds a few times a day btw.3
Yes, that did it. Thanks for providing this snippet!0
