Spouse Record, Head of Household, Divorce, Relationship record
Hi. Our foundation has been using RE/FE for about a 1 1/2 years. We recently had a situation where two constituents were linked as a spouses. We were notified of their divorce, and initially thought an "end date" on the relationship was the way to handle the change in the relationship. As we bounced off ideas for future processes, we realized that Head of Household processing would be affected if we didn't remove the spouse record. Another consideration would be if either constituent were to remarry, we wouldn't want there to be two spouse records. How are other RE customers handling divorces. Would anyone suggest adding a relationship type of "ex-spouse" to keep the history of both constituents?
    We change the relationship/reciprocal to "Former Spouse" and uncheck the spouse box name when they each have their own records.  This reformats our joint add/sal to only use the one name.  It should also gray out/ removed HOH as a factor.
    If it's a relationship record, does not have their own record in RE, the HOH is not affected.
    This has worked for us.
  • Thank you all for great ideas and suggestions!
  • If they are not separate but linked consitit records, make the spouse a constituent.
    Uncheck the Spouse check box.
    Change the relationship and recip relationship to ex-husband/wife/spouse.
    And lastly, uncheck the soft credit the spouse checkbox.
    Be sure to fix any oddities like address and phone number change, and addressee/salutations.
  • shani traum:
    We have a relationship type of former spouse that we would use on the records.  This way we have the historical biographical information still on both records.
    We change marital status to divorced.
    We uncheck the "spouse" box so as to break that connection.
    We remove combined name and salutation from both records.
    We remove/edit any other name option such as donor listing.
    If one of them remarries, the new spouse is treated as any spouse would be - marital status set to married, relationship set to spouse/spouse, check box checked, combined name/salutation added, etc.
    We also disable address sharing and try to get updated addresses as well.  We also ensure that the automatic soft-credit is disabled.
