Disabling multiple clicks to process button
Looking for an elegant way to not allow donors to hit the "submit" or "process" button on a donation form.  Anyone have a good solution.
  • A script like this should be able to disable the submit button after one click and still allow the request to go through.  In jQuery:
    $('input').one('click',function(){$(this).attr('disabled',true)})
  • mark.ajws :
    Where would place this code though? The process/submit buttons are system-generated.
  • Robert Saunders:
    Place it within the following snippet in the head element and make sure you have also included the jQuery library.
    $(document).ready(function(){
    //previous script code here
    </script>
    This approach would disable the button functionality from the front-end, but wont prevent the elements from actually being generated.  You could use a similar script or css to hide the buttons entirely.
  • mark.ajws :
    </script>
    You could also do this with Convio's JavaScript library, Utils.js,  which is automatically included in every Convio Online Marketing and CMS  page. No need for another library.
    addOnLoadHandler(function(){
    var i;
    var allForms=document.getElementsByTagName('form');
    for(i in allForms){
    Utils.addEvent(allForms,'submit',function(evt){
    var e=(evt)?evt:window.event;
    var elm=(e.target)?e.target:e.srcElement;
    var allInputs=elm.getElementsByTagName('input');
    for(j in allInputs){
    if(allInputs.type&&allInputs.type=='submit')
    allInputs.disabled=true;
    </script>
  • Noah Cooper:
    var i;
    for(i in allForms){
    </script>
    Hey Noah,
    Is there any documentation for the Utils.js library?
