Donate button
Is there a way to decrease spacing above and below a donate button?
Sophia
Sophia
Hi Sophia!
Thanks for posting in the community! I have two tips for you to try. Sometimes it takes some trial and error to get it how you would like it to look. I first would check out the padding option on the style tab - if you click in the column that the donate button is located and take out some of the padding that will sometimes help. Also, I am not sure where your donate button is located but I tend to keep it in it's own column instead of a column with other text or picures. I find I have much more control over the way it looks when i have it in it's own space. Does that make sense?
I hope so!
Michele Stender
Super helpful, thank you so much!!
Sophia0
