Image library
I have hundreds of images that have been loaded into Luminate through Page Builder.  But when I go to the Image Library, there are only four!  I want to replace some images that have changed on some pages, but the only thing I can do is to load a new image with a new name.  I can't update the images or delete the existing images.  The result is that I end up having three or four copies of the same image, all with a different name, and my set of images is three times the size it should be.
There has to be a solution to this.  Can anyone give me some advice?
Thanks.
  • Hey Jeff,
    This might be a long shot, but if you're only seeing 4 images and you know you've uploaded more than that, make sure to check to see if you have anything entered into the search field at the top of the image list. Or you can just click the "Show All" button to clear it out as well. That might be what's limiting the results to only 4.
    - Jon
    Jon Reich * Partner * Cathexis Partners * jon@cathexispartners.com * p.605.377.8147
  • Jon Reich
    Hey Jeff,
    - Jon
     That's it. I can't believe I missed that.  Thanks very much.  Jeff
  • Also, if you need to delete an image, you first move it to the Archive.  Then, you can view the Archived Images and select them for deletion from there.
