Load Default Sets updates to today's date with F3
I've created a default set to load in details about an Attribute. The Category, Description and Comments will remain the same whenver I use this. But I'd like to have it be today's date, not a fixed date.
Is there a way to avoid having to go in daily and edit the default set?
F5 will give you the current date, so when you load the default, the date will auto update.0
Just a clarification (because this is a recent find for me, and I had to go try it out to know that my understanding of the post I was reading was correct): When in the Setup for your Default Set, instead of entering a value in a Date Field within the Set, select the Date Field and press [F5]. RE will then show "Current system date" in that Date Field. And when you load the Set, the current date will be entered.0
Oops, I should have noted that Jennifer. Yes it will show in the default setup as "Current system date", but when you load the default on a record it will actually display the date.0
Thank you very much. I didn't know about <F5> putting in the current system date. Problem solved.0
