Enlarge image when mouseover
In storybuilder or pagebuilder, what do I need to do to get an image to enlarge when the mouse hovers over it?
  • Probably the easiest solution would be to do a regular javascript image swap. Just make the two images be 'regular size' (with some extra border) and 'large size' - but actually make both the same dimensions. (Which is 223x39 pixels in my example link.)
    Here's a link to my site that is using a nice JS image swap script.
    http://www.heroesforlife.org/changemakers_2010_home
    The key parts are this script...
    <script language="JavaScript" type="text/javascript">
    browserok = (((navigator.appName == "Netscape") && (parseInt(navigator.appVersion) >= 3)) || ((navigator.appName == "Microsoft Internet Explorer") && (parseInt(navigator.appVersion)>=3)));
    if(browserok)
    getabagOn = new Image(223, 39);
    getabagOn.src="../_wrappers/changemakers/2010/button-getabag-on.gif";
    getabagOff = new Image(223, 39);
    getabagOff.src="../_wrappers/changemakers/2010/button-getabag-off.gif";
    function mouseOn(imgName)
    if(browserok)
    imageOn = eval(imgName + "On.src");
    document .src=imageOn;
    function mouseOff(imgName)
    if(browserok)
    imageOff = eval(imgName + "Off.src");
    document .src=imageOff;
    </script>
    And the code on the IMG tags...
    <img src="../images/button-getabag-off.gif" width="223" height="39" id="getabag" name="getabag" onmouseover="mouseOn('getabag'); return true;" onmouseout="mouseOff('getabag')" />
    If you look at the source on my page, you'll see how to use this with more that one image. (I also add a little script that flashes my images on pageload as a hint to users that the images do something.)
  • Brian Mucha:
    if(browserok)
    if(browserok)
    if(browserok)
    </script>
    Thank you so much for your reply, Brian. As somebody with very limited experience in Javascript, I need input on how to go about doing this. Because this is more advanced, we're considering doing the window-popup thing instead. However, I think the image mouseover looks way cooler
  • Adria Pazour:
    If you change your mind feel free to contact me. Its easier than it looks.
    B
  • Brian Mucha:
    B
    Yes, I would love and appreciate your help on this! I like hearing "easier than it looks".
  • Brian Mucha:
    B
    Brian,
    Kudos to you, always so helpful!!
    I was trying to explain this to Tessa at work. Can't she just upload two sizes of image, the one she is displaying in story builder and a larger one. Then link the one in the story (smaller one) to a popup window to the larger image - wouldn't it all be in the url string, not java script?
    I seem to recall seeing this and learning it awhile back, but I've never done this and I am not exactly sure how to do it.
    I've never done mouseover either, just once for practice in a class.
    Thanks again for always being so helpful!
    Nikki
  • Nikki Valentine Odens:
    Brian,
    Nikki
  • Brian Mucha:
    Sorry pop up window is what I've always thought it was called , when a new browser window opens up w/o any tool bars or search bar, just a window with image. I've only seen them done with images. Of course now I can't think of an example of when I've seen this.
    Ahhh, now I see. You want kind of a thumbnail that shows a much  bigger full size image somewhere else. (For some reason I took mouseover to mean you wanted the image to get a bit bigger IN PLACE when you passed over it.)
    If you are really doing a pop-up I wouldn't do that on  mouseover, but onCLICK. There's a bazillion javascripts around to do pop-ups like that. Here's the one I've used.
    <script type='text/javascript'>
    function PopDialog(URLString, winWidth, winHeight){
    var windowProperties = '';
    windowProperties = windowProperties + 'fullscreen=no,';
    windowProperties = windowProperties + 'toolbar=no,';
    windowProperties = windowProperties + 'location=no,';
    windowProperties = windowProperties + 'directories=no,';
    windowProperties = windowProperties + 'status=no,';
    windowProperties = windowProperties + 'menubar=no,';
    windowProperties = windowProperties + 'scrollbars=no,';
    windowProperties = windowProperties + 'resizable=yes,';
    windowProperties = windowProperties + 'top=50,';
    windowProperties = windowProperties + 'left=100,';
    windowProperties = windowProperties + 'width=' + winWidth + ',';
    windowProperties = windowProperties + 'height=' + winHeight;
    var win = window.open(URLString, '', windowProperties);
    </script>
    Call it like this...
    <a href="images/myBigImage.jpg" onClick="PopDialog('images/myBigImage.jpg', 600, 800); return false;"><img scr="myThumbnail.gif" /></a>
  • Brian Mucha:
    </script>
    " (For some reason I took mouseover to mean you wanted the image to get a bit bigger IN PLACE when you passed over it.)"
    Just to clarify, that is what I wanted when I began this discussion. However, Nikki is saying the window pop-up thing is much simpler.
    Sorry for the confusion!
  • Adria Pazour:
    No worries, prolly my fault. Never assume!
    The pop-up is much simplier.
    You could also make the big version just appear on the page when the thumbnail is moused-over, but it would get a bit more complex.
    B
  • Brian Mucha:
    B
    Are you trying to do something like this?
    http://cssglobe.com/lab/tooltip/02/
    If so, here are the instructions on how to do it using jQuery:
    http://cssglobe.com/post/1695/easiest-tooltip-and-image-preview-using-jquery
  • Noah Cooper:
    Noah - YES! Thank you! I will look into what you gave me and update -
  • Noah Cooper:
    Hah, that is too nice.
    I have a script around somewhere to do nothing but that exact tooltip thing that must be 400 lines long.
    B
  • Noah Cooper:
    Please see attached.   Thank you so much!
    Message was edited by: Tessa
  • Noah Cooper:
    Noah,
    Jen and I tried this using the jquery article we used it didn't work. Do we need to declare this somehwere? Since this is a pagebuilder page using HTML?
    <div class="campusHighlights"><a title="Preserve Lakota culture for the children"
    <strong>
    <a href="http://www.stjo.org/images/content/pagebuilder/14825.jpg" class="preview">
    <img src="http://www.stjo.org/images/content/pagebuilder/14837.jpg" alt="gallery thumbnail"/></a>
    </strong></a><strong>Preserve Lakota culture for the children</strong><br />Provide boys and girls at St. Joseph&#8217;s with the powwow regalia they need to continue this important tradition! <a title="Preserve Lakota culture for the children"<a href="http://www.stjo.org/help_cpf_b" target="_self">Support our Cultural Preservation Fund</a> <span class="arrowBlue">&raquo;</span></div>
    </td>
    </tr>
    Here is how it looks it just pulled the larger image.
    Thanks for your help.
  • Noah Cooper:
    Okay, I tried using the image preview (jQuery tooltip), but have been unsuccessful. Am I missing something?
    <tr>
    <td>
    <div class="campusHighlights"><a title="Give the gift culture" href="http://www.stjo.org/site/News2?page=NewsArticle&amp;id=6874" target="_self">
    <img src="http://www.stjo.org/images/content/pagebuilder/14825.jpg" class="preview" img src="http://www.stjo.org/images/content/pagebuilder/14837.jpg" border="0"/></a>
    <strong>Give the gift culture</strong><br />
    Cultural education provides the youngsters at our school with the tools to preserve their proud culture to learn about their heritage and to build a bright future. As Lakota (Sioux) elders pass on, cultural education becomes more important than ever."
    <a title="Give the gift culture" href="News2?page=NewsArticle&amp;id=6874">Watch our video</a> <span class="arrowBlue">&raquo;</span> </div>
    </td>
    </tr>
