Is there a way to block a Survey Title from being seen?
A code or something to plug in as html like you can to block the skip and cancel buttons? Thanks!
  • There are two possible solutions:
    1) Insert the Survey in a PageBuilder page using the WYSIWYG Component. When a Survey is included in this way, the title is not included.
    2) Use the following style:
    <style type="text/css">
    h3.ObjTitle{
    display:none;
    </style>
    You can either put this style in a Caption question on an individual Survey level, or, add it to your page wrapper like so to apply it to all Surveys:
    ]x::
    h3.ObjTitle{
    display:none;
    </style>
  • Noah Cooper:
    h3.ObjTitle{
    display:none;
    </style>
    ]x::
    h3.ObjTitle{
    display:none;
    </style>
    Noah.. thank you SOOO much! Worked like a charm.
