Is there a way to globally check all boxes in a list
I'm sure I'm not using the correct terminology but we have a Luminate donation form we are using for an event and one element on the page is a list of table captains. Every time I make a change to the list of table captains, I need to re check all the boxes in the list for the table captains to make everything appear correctly on the donation form.
Is there a function within Luminate where you can check all so I do not need to individually check each box every time?
thanks for any help!
joanne
From your browser's development console:
var chkboxes = document.querySelectorAll('input[type="checkbox"]');<br /><br/>for (var i = 0; i < chkboxes.length; i++) {<br /><br/> chkboxes[i].checked = true;<br /><br/>}<br /><br/>
This will select and check ALL <input type="checkbox"> on a page. If you need to select only checkboxes in a specific element, you'll need to select that element first:
var chkboxParent = document.querySelector('#checkboxListExample');<br /><br/>var chkboxes = chkboxParent.querySelectorAll('input[type="checkbox"]');<br /><br/>
And if you need your code to be XML-compliant, you'll need to change the ".checked" value on the chkboxes array:
chkboxes[i].checked = 'checked';<br /><br/>
Mark Kindy:
Thanks Mark! Appreciate the response but this is all Greek to me, but I'll talk to my web designer about it. Happy New Year!
Google Chrome has a plug in called Check All by Tejji. You can click it to automatically check or uncheck everything on the page. I use it often.0
