Primary Addressee
Hello - I am setting up OLX for the first time and when I go to process a batch of transactions, I get the error "required field missing primary addresse". Can anyone help me figure out how to set this so that I can do a batch without having to go into each record and select this field?
Thanks
Thanks
Contessa - I am guessing that your org has a Business Rule that requires Primary Addressee on any record. Check in your Configuration Settings - Fields - Constituent. If Primary Addressee is checked - uncheck it.
