Gift Note requires loading Default Set twice?
I'm using a Default Set to enter some gifts, and it includes a Gift Note. However, when I load the Default Set, I have to click [New Notepad] and then Shift+F2 to load the Default Set again for the Note. Has anyone ever noticed this before? Any way to get it to add the Note when I load the Default Set on the Gift Record itself? Not a huge deal, but a bit of a pain in the neck.
Hi Jennifer! The issue may stem from the original default set. When you go into the Tools menu and Organize/Create Defaults, have you ensured that there is some data in the Notes section? That might solve the problem. Also, there's a knowledgebase article (69311) that talks about loading the set twice. This may stem from the fact that a Note is kind of like a "subrecord" of sorts, beneath the gift record if you will. Clicking Shift+ F2 a second time as you have been doing is an easy workaround to ensure the information gets entered.0
Thanks, Rachel. There is data in the Notes section, because it puts it in there once I create a Note and reload the Default Set. And the KB Solution talks about the check box for [Load Default Values Now], which has to be checked for any Gift Default Set to work. I just wondered, because on a Constituent Record, I have a Default Set that loads the Constituent Note along with the other data in the Set. Thought maybe I was missing something since the two operate differently, while doing essentially the same thing.1
Hi Jennifer. I have the same issue and agree that this is inconsistent with the behaviour of default sets for new constituents. Thankfully I do not use gift notes often.1
