Deleting Constituent Codes
Emily - I would recommend assessing how you use the constituent codes now. If there are codes you are not using and you cannot think of how you might use them, then you should probably get rid of them. What value are they to you if you are not using them?
Gina Gerhard:
Thanks for your reply, Gina! I appreciate your input.
"Have any of you encountered this issue before?"
I can't imagine any of us who HAVEN'T encountered this issue before.1 -
John Heizer:
I can't imagine any of us who HAVEN'T encountered this issue before.Ha!
If you don't know what they mean, chances are, you'll never need them. If there is concern about losing data that you might find you need later, I would export the data and archive it, then remove it from the database. Just write a Query for each one, with ConstID and maybe ImportID and Name, export the data directly from the Query to Excel, and use a Global Change to remove the code from RE. Once you've completed the process, you can delete the table entries in Config, and combine all the Excel sheets into one single document. Then you can attach that document to a dummy record in RE so it's archived, but still available and still in RE rather than floating out there somewhere where no one will ever find it. I keep several dummy records, with a Constituent Code of "Dummy Record" and a ConstID of 4561231, 4561232, etc. for different purposes, many to do with gifts from Unknown Donors and Media Files of things I want in RE but don't have a logical place to keep them. (I also have a set of dummy records for testing purposes, those are 4567891, etc.)1
Jennifer Claudy:
If you don't know what they mean, chances are, you'll never need them. If there is concern about losing data that you might find you need later, I would export the data and archive it, then remove it from the database. Just write a Query for each one, with ConstID and maybe ImportID and Name, export the data directly from the Query to Excel, and use a Global Change to remove the code from RE. Once you've completed the process, you can delete the table entries in Config, and combine all the Excel sheets into one single document. Then you can attach that document to a dummy record in RE so it's archived, but still available and still in RE rather than floating out there somewhere where no one will ever find it. I keep several dummy records, with a Constituent Code of "Dummy Record" and a ConstID of 4561231, 4561232, etc. for different purposes, many to do with gifts from Unknown Donors and Media Files of things I want in RE but don't have a logical place to keep them. (I also have a set of dummy records for testing purposes, those are 4567891, etc.)Hi Jennifer! Great idea! Thank you for the helpful tips!
We are in a similar situation with so many new team members and no one knowing what was done before.
We went ahead and changed our codes: constituency primarily. So far so good but we were able to keep a backup just in case0 -
Angel Quinn:
We went ahead and changed our codes: constituency primarily. So far so good but we were able to keep a backup just in caseThanks, Angel!
How true - we've all had this! The Constituent Code seems to have been used in place of appeals in many instances. I'd like to make sure that no one has more than 3 codes - I can't picture a scenario in which you need to be identified as more than that. I also discovered (rather late in the day!) that you can query on the Primary Constituent Code - the one that is highlighted. That set me on a campaign to get people's multiple codes into order. I am a little shy of using global changes or add/deletes and our database is relatively small, so I set up queries to hunt down active records with garbage attached and set the poor work-studies to fix them by hand! Mind-numbingly boring, but at least they get a paycheck for it!
Gracie0 -
Gracie Schild:
GracieHi Gracie. We actually had the same issue with our codes! The previous users were using them in place of appeals, as well. It can definitely be frustrating! I'm also a little weary of global changes. I've done two in our system, but it always makes me nervous, even with our system getting backed up!
Gracie Schild:
GracieIf you'd like to keep your constituent codes in a consistent order in the future - you can re-organize your constituency code table to be in hierarchical order. That way,when data entry is being done you can look at the drop-down menu and just put codes in using the same order.
The hardest part? Getting everyone at your organization to agree on an order! I've found food bribes tend to smooth some of that over.
Amy Matthews:
Gracie Schild:
The hardest part? Getting everyone at your organization to agree on an order! I've found food bribes tend to smooth some of that over.Hi Amy,
This has been a really useful post to stumble across!
This might be a daft question - but if you re-order the hierarchy of your constituent codes in the Config - Tables, does this automatically re-order them on all your RE records? This may be a bit of wishful thinking on my part! Ours have become quite muddled so it would be great for the current donor codes we use to move up to being the primary constituent code!
Thanks in advance,
Jess
Unfortunately, I don't think re-organizing your Constituent code table will re-order the codes in donor records. However, there is a Knowledgebas article on how to use Global Add/Delete to make a Constituent code Primary in all records that need it. See https://kb.blackbaud.com/articles/Article/399360
Hi Jessica,
Unfortunately, it is wishful thinking (I'll add my wishes to yours!) I would probably recommend using Import & Excel sorting as a clean up tool if you want to make sure all of your older codes are in a consistent order. If all you need is the primary code to be correct though, the Global Add/ Delete method Murray linked to will work.0 -
Thank you very much both of you, that's really helpful!
Cheers,
Jess0 -
Amy Matthews:
Gracie Schild:
The hardest part? Getting everyone at your organization to agree on an order! I've found food bribes tend to smooth some of that over.and if you really want to be sure that everyone understands that the order in the drop down is the Hierarchy - number them. 1.Board 2. Alum etc.
We plan to start this process very soon. Thanks for all the great information. I think doing a SOP for how we use CC will help us greatly.0
