Formula required for Attribute information
Hi,
I am new to Crystal Reports and wondered if someone could help me?
I am trying to run a sub report to group Attribute Benefits.
I am running a report to see who has a benefit of 'Christmas Card' or 'Christmas E-Card' or Both.
In my sub report I have created the following formula but it is not showing if a constituent has both benefits on their record.
If {CnAttrCat_1.CnAttrCat_1_Description} = "Christmas Card" then "Xmas Card"
else if {CnAttrCat_1.CnAttrCat_1_Description} = "Christmas E-Card" then "Xmas E-Card"
else if {CnAttrCat_1.CnAttrCat_1_Description} = "Christmas Card" and {CnAttrCat_1.CnAttrCat_1_Description} = "Christmas E-Card" then "Both"
Any help would be appreciated.
Thanks, Ryan
  • Hi Ryan,
    The reason it is not showing if a constituent has both attributes is because the formula is testing each attribute to see if it meets the criteria, and a single attribute cannot be equal to both "Christmas Card" and "Christmas E-Card".
    The way I would do this would be to create 2 formulas to assign a value of 1 to each attribute:
    If {CnAttrCat_1.CnAttrCat_1_Description} = "Christmas Card" then 1
    and in a separate formula:
    If {CnAttrCat_1.CnAttrCat_1_Description} = "Christmas E-Card" then 1
    and then group your report by constituent ID and insert a summary to the group header for each of these formulas. If the constituent has both attributes then the group header will contain two 1s, otherwise they will have a 1 and a 0.
  • Alan French:
    Hi Ryan,
    Hi Alan,
    Thank you so much for replying, I really appreciate it. When I insert a summary would I group it by Count or Max?
    I have created something similar but was asked whether I could get the information into one box instead of having each individual box for Christmas Card and E-Card. Do you think its impossible to achieve this type of request within one formula?
  • Hi Alan,
  • Use Maximum for the summary. Count would not distinguish between a 0 or a 1 as it is just testing to see if the field contains a number.
    Yes it's possible to get the info into one field. If you create a third formula that looks at the values of the 2 summaries, then drop this into the group header, this should give you the result you're after (replace attribute1 and attribute2 with the names of your first 2 formulas):
    if Maximum ({@attribute1}, {CnBio.CnBio_ID}) > 0 then
        if Maximum ({@attribute2}, {CnBio.CnBio_ID}) > 0 then
            "Both"
        else "Xmas Card"
    else if Maximum ({@attribute2}, {CnBio.CnBio_ID}) > 0 then
        "Xmas E-Card"
  • Alan,
    Thank you so much, this worked perfectly. I really appreciate your help with this.
    Thanks again.
    Ryan
  • No problem, glad I could be of help smiley
  • Hi Alan,
    Thank you so much for your help the other week with this question. I was wondering if the formula below is possible with the option of 3 benefits?
    So previously we was looking at Christmas Card and Christmas E-Card and you suggested the formula of -
            "Both"
        else "Xmas Card"
        "Xmas E-Card"
    I have tried to amend the formula to include the options for 3 benefits but just can't seem to get it to work, can you help please?
    Thanks in advance.
  • There's probably a more elegant method to do this, but my ham-fisted approach is as follows.
    If you create a new formula for the third benefit (I don't know what your third benefit is called, so you'll need to replace "Foo" with the actual description of the attribute):
    If {CnAttrCat_1.CnAttrCat_1_Description} = "Foo" then 1
    Then edit your formula that's in the group header to this:
    if maximum({@attribute1},{CnBio.CnBio_ID}) > 0 then
        if maximum({@attribute2},{CnBio.CnBio_ID}) > 0 then
            if maximum({@attribute3},{CnBio.CnBio_ID}) > 0 then
                "Benefits 1, 2, 3"
            else
                "Benefits 1, 2"
        else
                "Benefits 1, 3"
            else
                "Benefit 1"
    else
                "Benefits 2, 3"
            else
                "Benefit 2"
        else
                "Benefit 3"
    Then you can change all the values in the quotes to reflect what the actual benefits are, e.g. "Christmas Card, Christmas E-Card, Christmas SMS" instead of "Benefits 1, 2, 3" smiley
  • Hi Alan,
    I really appreciate you helping me out with this, thank you so much. You have helped me out again big time!
    Hope you have a nice weekend.
    Thanks, Ryan
