Globally Changing Constituent Notepad Types
Hi Everyone,
I recently added a constituent note to over 400,000 records in our system to mark these records had been researched by a data append service. I used an existing notepad type that is currently used for all things related to research on a constituent. I have been asked to change all the data append notes to a different notepad type, so that the note is more distinct. This presents a problem because some of the constituents have multiple instances of the existing notepad type on their record and a global change would replace the notepad type on all of the notes when I just need a subset of the notes to be changed. Any creative ideas on how I can globally change this subset of 400,000+ notepad types?
Hi Matthew,
Assuming you added all the notes on the same day, can you create a query to obtain the import IDs for notes of that type created by you on that date, then create a Constituent Notepad import and use those IDs to update just the notes you're interested in? Import does give a bit more control than Global Add over exactly which records get changed.0 -
Hi Alan,
Thanks so much for your help! That worked perfectly. I was able to change all 400,000 notepads.
Thanks again!0
