Spouse Relationships
I think that it's not possible and the only way is to just do a non-constituent relationship or for the secondary person to get their own records and mark the other one as HOH. Just curious if anyone has any brilliant ideas I have not considered!
Thanks in advance!
I do not believe it is possible to create a relationship link between two non-constituent records. One of them must have an actual constituent record, because otherwise, there is no where for that relationship link to exist. What you can do is create a Relationship Type of "Relation to Spouse" or "Friend of Spouse" and then add a Note on the Relationship link. So in your example, the link could be either between Sally & Mary with "Friend of Spouse" as both Relationship and Reciprocal and a Note on that Relationship Record indicating that it is Bob & Joe who are friends, or (more complex) a link from Mary to Joe and another from Sally to Bob using the same Relationship Type. I would personally opt for the first. If the relationship is so important as to need a complicated solution, I would think Bob and or Joe would warrent having their own constituent records.0
Jennifer Claudy:
I do not believe it is possible to create a relationship link between two non-constituent records. One of them must have an actual constituent record, because otherwise, there is no where for that relationship link to exist. What you can do is create a Relationship Type of "Relation to Spouse" or "Friend of Spouse" and then add a Note on the Relationship link. So in your example, the link could be either between Sally & Mary with "Friend of Spouse" as both Relationship and Reciprocal and a Note on that Relationship Record indicating that it is Bob & Joe who are friends, or (more complex) a link from Mary to Joe and another from Sally to Bob using the same Relationship Type. I would personally opt for the first. If the relationship is so important as to need a complicated solution, I would think Bob and or Joe would warrent having their own constituent records.Thank you! I like the idea of changing/adding the relationship type, I think that will work well. I also agree about you idea about when their own record might be warrented. Thanks so much for your thoughts!
