Importing a List
I have imported a list into NetCommunity but when I go to the 'send an message' area and try to select this list, the imported list does not show up as an option. Any help is appreciated.
Hey RV,
The data source on your template is incorrect. If you want to use merge fields the data source needs to be that specific imported list. If you don't want to use merge fields the data source needs to be none. You can use these steps to update that without losing your work. http://www.blackbaud.com/kb/index?pag...
Karen0 -
Thanks Karen it worked!0
