How to add merge fields to a constituent list
I'm new to the party.... so is there yet a way to add whatever RE merge fields we want. A constituent list should be able to pull from the RE and grab whatever fields are therein.
Note: This topic was created from a reply on the Add more email merge fields topic.
  • Hello Christine,
    Constituent attributes can be added as merge fields provided we mark them of under Administration, Sites & settings.
    Karen
  • I will give that a try. Thanks.
  • Karen there is still a limited amount of fields available under sites and settings.
    I've just started working with BBNC and was initially frustrated with the same issue of the limited merge fields available in NC. There is a work around. while not ideal it's a decent temporary solution. If you export a report out of RE into a CSV file, with the data and merge fields you'd like to use for any given, by importing this list into BBNC. We've just used this process to email pledge reminders. I like the rest of you would prefer a more straight forward method of doing this. but for the time being this is an option
  • Hello Sasha,
    There's an idea out there to add more merge fields. Please add your voice to this thread. http://bbnccommunity.blackbaud.com/bb...
    Karen
