Embedded video not displaying while logged into NetCommunity
Hello!
I post all embed code from youtube, etc... to an unformatted text part. It works great, but you can only see the content if you log out of netcommunity. How can I see what I embedded while still logged in?
An example is that I have a part with a video that is scheduled to publish at midnight the next day. How do I know if it worked? I can't see it while logged in, and the part is unpublished, so I can't see it when I log out.
Is it normal behavior for the unformatted text part not to display anything to the screen while you are logged in?
Hey John,
When I've seen this before it was an SSL error. Try changing all the http references to https and see if it works then.
Karen0 -
Karen's answer should fix the problem, however I would suggest not using http or https, alter the code so looks something like this:
src="//www.youtube.com/embed
This will make the browser request the correct http/https each time the page is loaded.0 -
Thanks for both the quick replies!
I found the problem, and it was actually some rogue javascript in the embed link. Once that was gone, everything worked!0
