Additional Merge Fields in Online Express Email Marketing?
Is there a way to insert merge info per constituent, like preferred address or salutation from RE, into the body of an online express email?
  • Matthew Garbarino
    Matthew Garbarino Blackbaud Employee
    Tenth Anniversary Facilitator 3 Photogenic
    Hi Peter. Yes, you can all various merge fields into marketing emails. Simply add a text widget to your email then select the right field from the "Merge field" menu at the top right.
    Note that the addressee/salutation fields need to be mapped by visiting Account then Integration options and finding the addressee/salutation section.
  • Just to clarify, can you use *preferred* salutation as a merge field in OLX emails?
  • Matthew Garbarino
    Jennifer Chase:
    Hi Jennifer! You can map up to three different add/sal types from the account > integration options menu. Then you can select those merge fields for email marketing and use them as appropriate.
  • Thanks, Matt!
  • How do I add a text widget to OLX?
    Thanks
