Applying Gifts to the Planned Gift Type
We keep all gifts on the original constituent record, with the reference reading made possible through....
We change the name of the trustee or executor on the main letter and add them as a relationship.
If by chance the gift needs to be sent elsewhere, we make a new record, link them through relationships and soft credit the deceased.1 -
We create a new separate constituent (org type) record for estates since an estate is a separate legal entity (according to the IRS), and we then link them via Relationships. The discussions we have had here (and I've had elsewhere) about converting the individual record to the estate record have mostly revolved around wanting the constituent's giving "all in one place" and on the same record so they can see previous giving. I've asked and I've never been given an answer as to "why?", especially after I remind them that the constituent has passed and, hopefully. will no longer be solicited or included in our moves management process.
If they want to see the gifts on the spouse's record then we soft credit the past gifts. An org record also allows for the entry of and mailing to related contacts such as attorneys and executors.
We also found out (after purchasing the module) that a Planned Gift, er, gift (i.e. bequest) cannot be applied to a Planned Gift on another record. We still stick with the above policies and just mark the Planned Gift as realized on the individual's record.5 -
We also use the Planned Gift module and found the limitation of only using a single constituent pretty annoying. We put the planned gift on the individual record when the person is still alive.
Once the person passes away and we receive a gift from the estate we create a new Estate record, re-create the planned gift (with the original date) on the Estate record and then process the payment. We also create a relationship between the Estate record and individual record (we use "Estate" and "Estate Namesake" for the relationship types)...
Be really, really careful with planned gifts. We like Raiser's Edge, but we really think Blackbaud messed this one up pretty good. It's nearly impossible to count Planned Gifts as "pledges" and realized gifts in as "payments" on most standard reports. This means it's real easy to double-count things when you're looking at a 5 or 10 year period of income.
Example: Let's say you're looking at "committed" money in (pledges and outright gifts...no payments). If you just query on the gift types you might get a Planned Gift for $100,000 as well as the outright Cash gift of $100,000. That adds up to $200k, when you really only have half that. You have to remember to only grab Cash gifts that are "not linked to a Planned Gift" in this example, though in some tallies screens you really can't factor those out.
Good luck!3 -
Thomas - I thought the planned gifts went in with a gift type of 'planned gift' so wouldn't those be extractable in your gift reporting?0
Unfortunately, we do not have the planned gift module so "planned gift" as gift type is not available.
I thought of entering as gift type of "other" on the individual record and creating a new gift sub type of planned gift or DAF. When funds actually received they would be entered on DAF record with soft credit to individual. Thoughts?0 -
Planned Gifts do go in as "Planned Gifts" but we also count that as a committment, so they're the same as a pledge. We will often include Planned Gifts with pledges in our reporting. When you're counting "committed" money you generally will add up all outright gifts as well as all committments.
The problem is that payment against Planned Gifts are sees in RE as "Cash" not "Payments"....2 -
Thomas Klimchak:
Good luck!
This is exactly what I was complaining about yesterday. At this point, I'm so used to reporting by dumping everything out of RE and calculating things myself, that I didn't notice there was a "total realized" field I could export to avoid double counting.0 -
Currently, our organization creates a "planned gift" (using the planned giving module) on a constituent record when they indicate that they would like to make a gift. This doesn't mean we will ever get any money. Neither does a letter of intent for that matter.
It's our policy that an "individual" makes gifts and can alert us to a planned gift, but we create organizational records for the actual estate when the money comes in. We don't want to make estate records until an individual dies - so we don't put the planned gift on the estate record we put it on the individual. Like I said, you never really know if you'll get any money, so why make the records until you need them? But when the money comes in we can't apply it to the individual's planned gift.
I don't like converting the individual to an organization because I think you lose the history. We also don't like to create the estate record for the purpose of recording the planned gift, becuase it leads to confusion. Lots of "Is he dead?!?!" calls.
It's a problem.
http://rediscovery.uservoice.com/forums/137015-raiser-s-edge-discovery-topics/suggestions/3013162-need-to-be-able-to-apply-gift-to-a-planned-gift-on0 -
Thomas Klimchak:
The problem is that payment against Planned Gifts are sees in RE as "Cash" not "Payments"....Thomas,
We are doing the same process here with the Individual constituent having the Planned Gift and once deceased the Estate of constituent record is created with the Realized Bequest cash gift. Have you ever come across the situation where the Planned Gift was higher (250K) than the actual Realized Bequest(45K)? How did you make the adjustment? We added the 45K gift to the "Estate of ..." as a cash gift but back in 2014 we have Expected Bequest with 250K in reports.
Kathi
Sorry for the slow response... Yes, we have had large planned gifts that ended up being a lot smaller when they were actually realized. We don't have a lot of them, but in the few cases where it's happened we ended up revising the original Planned Gift record downward so match the actual realized amount.
The same sort of problem can happen when you are counting Pledges as "committed" money and then someone passes away or says they won't pay off their pledge. You can write off the balance, but that doesn't change the original pledge (committed) amount... The original pledge amount is still there as a "committed" number even though you know you're never going to receive the money.0 -
Is anyone 'realizing' the planned gift on the original Planned Gift (on the deceased record), and then soft crediting the Estate record? Thank you!0
Thomas,
Thanks for your response. We can’t
change the PG due to our processes. We need to make an
adjustment in the current fiscal year showing a decrease in the
Planned Gift column of our reports. We decided to change our
business process with Planned Gifts to create the Estate record
when a PG is accepted and then once the individual passes and we
receive the gift, we link the received gift to the PG and we get
the Total Realized which can be used to calculate the
adjustment.It seems a bit dramatic to have to make this
business process change but in the long run it seems to give us the
amounts we need for reporting.Thanks,
Kathi
Kathi
McKelveyVoice:
520-621-1939
1111 N Cherry Ave, Room 305
Tucson, AZ 85721-01090 -
Hi Erika,
No we can’t change the PG on the individual
because it has been reported in previous year’s Campaign
report. Since we put the actual gift received on the Estate
record we can’t link the received gift to the PG to get Total
Realized. Thanks for your response. We need to make an
Kathi
Kathi
McKelveyVoice:
520-621-1939
