Is there a reliable tool to determine cities within a certain radius of a city
Thanks.
We use MapPoint for this but unfortunately Microsoft has discontinued it, so I'm not much help. Sorry!2
We use O-Matic Software’s record
radius
Christine E.
AdamsSenior
Director of Advancement ServicesUniversity
of HartfordOffice
of Institutional Advancement200
Bloomfield AvenueWest
Hartford, CT 06117P
860.768.2407C
860.461.6374F
860.768.2454
This message is intended only for
the use of the addressee and may contain information that is
privileged, confidential and exempt from disclosure under
applicable law. If the reader of this message is not the intended
recipient, or the employee or agent responsible for delivering the
message to the intended recipient, you are hereby notified that any
dissemination, distribution or copying of this communication is
strictly prohibited. If you have received this communication in
error, please advise the sender by reply e-mail of the error and
then delete this e-mail immediately. Thank you5 -
We use this website: http://www.freemaptools.com/find-zip-codes-inside-radius.htm5
Josh Bekerman:
We use MapPoint for this but unfortunately Microsoft has discontinued it, so I'm not much help. Sorry!Oh, lovely. I use it a lot, too. Are you going to keep MP or switch to something else?2 -
http://www.omaticsoftware.com/ record radar. It's a great plugin for Raiser's Edge.3
Carolyn Moatz:
We use this website: http://www.freemaptools.com/find-zip-codes-inside-radius.htm2 -
Kate Sklodowska:
http://www.omaticsoftware.com/ record radar. It's a great plugin for Raiser's Edge.2 -
Christine Adams:
We use O-Matic Software’s record radius
Thanks! I've already looked at their demo and hope to get it!
Christine E. Adams
Senior Director of Advancement Services
University of Hartford
Office of Institutional Advancement
200 Bloomfield Avenue
West Hartford, CT 06117
P 860.768.2407
C 860.461.6374
F 860.768.2454
This message is intended only for the use of the addressee and may contain information that is privileged, confidential and exempt from disclosure under applicable law. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering the message to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please advise the sender by reply e-mail of the error and then delete this e-mail immediately. Thank you
Robin Richardson:
Carolyn Moatz:
We use this website: http://www.freemaptools.com/find-zip-codes-inside-radius.htmI find it easier to use the zip codes. Some zip codes around here have more than one acceptable town name associated it with it, so it also ensures we don't miss people who use a different name for the same zip code.3 -
I have found some success through Google. e.g. "radius 80 miles from Calgary AB". The site I choose is www.distance-calculator.co.uk
Carolyn Moatz:
We use this website: http://www.freemaptools.com/find-zip-codes-inside-radius.htmOur organization recently switched from eTapestry to Raiser's Edge. We use radius searches quite often with our alumni constituents, and this feature was built in on eTapestry. I stumbled across the website above in trying to solve the problem of lack of a radius search in RE. Is there an easy way to enter ZIP codes into a query in RE? So far, I seem to be limited by the fact that a "one of" query requires that the ZIPs all be on separate lines, which is extremely problematic when working with a radius that includes 100+ ZIP codes. Anyone have any suggestions for making this easier that does not include the purchase of the RecordRadar plugin?
www.MelissaData.com is a resource I use fairly frequently. Not sure it will solve anyone's needs, but there's a free version that offers quite a variety.
to Angela, I have two thoughts:
You can Query using a series of "begins with..." and the AND function, or if you have a list of the 100+ zip codes you can paste them into a One Of operator. Just copy the list to your clipboard, open the One Of window, click down at least one page of rows (or all the way to the bottom), select an empty row, click Ctrl+V to paste, then OK and you should have your list. This works for up to 500 values per line of Criteria.
The other thing you could do is utilize the Region Field on the Address Records. When adding new addresses, you would need to populate this field, or periodically go thru and populate all new addresses with a blank Region...and you'll need to be careful when copying the address as an alternate because the Region will remain as-is unless you change it when updating the address. Not sure this will work for you, but it's what I was planning to do for a tracking measure I was almost ready to implement before they decided they didn't need that data anymore. If Region doesn't work, there are also Address Attributes.4 -
Jen Claudy:
The other thing you could do is utilize the Region Field on the Address Records. When adding new addresses, you would need to populate this field, or periodically go thru and populate all new addresses with a blank Region...and you'll need to be careful when copying the address as an alternate because the Region will remain as-is unless you change it when updating the address. Not sure this will work for you, but it's what I was planning to do for a tracking measure I was almost ready to implement before they decided they didn't need that data anymore. If Region doesn't work, there are also Address Attributes.Jen,
When you copy and paste multiple zip codes how do you account for zips with the +4?
3 -
Daniel Snyder:
You really can't, unfortunately. My assumption was that Angela was using only 5-digit zips. It would probably be worth posting (or looking to see if it's already posted) in the RE7 Idea Bank to provide the option to have RE disregard +4 zips in Query Criteria. Which is already submitted....
Check out the following in the RE7 Idea Bank: Radius Search in Query (as well as Radius Search Please, posted by Angela yesterday) and Zip (which adds to an older Idea, Query Using Wildcards). There are a few others that came up with my search words of "query zip" and probably many more with other search terms. But go Vote, because that's the best way to make your voice heard about what you want to see.
4 -
Daniel Snyder:
Jen Claudy:
When you copy and paste multiple zip codes how do you account for zips with the +4?We still use our old region queries, but have also purchased RecordRadar and are probably going to to a mix of both, as RecordRadar is by radius from a specific zip, and or queries are based on zips. The problem with using radius is that you could miss half a town because the other half is just beyond the radius parameters.
We run our region queries once a month. Basically, we looked at cities or areas where we wanted to send targeted mailings, figured out what zips were in the zone, and built two queries for each, one to add the region code to the records in that area and one to remove the region code from records that are no longer in that region.
Here is a sample of one of our regions:
Region - Add Chicago North
(Preferred ZIP between 60000 AND 60099-9999
OR Preferred ZIP between 60200 AND 60299-9999
OR Preferred ZIP between 60700 AND 60799-9999
OR Preferred ZIP between 60666 AND 60666-9999)
AND Preferred Region does not equal Chicago - North
AND (Preferred Region equals United States
OR Preferred Country Blank)
Region - Remove Chicago North
(Preferred ZIP not between 60000 AND 60099-9999
AND Preferred ZIP not between 60200 AND 60299-9999
AND Preferred ZIP not between 60700 AND 60799-9999
AND Preferred ZIP not between 60666 AND 60666-9999)
AND Preferred Region equals Chicago - North
Hi Daniel,
I use the same MelissaData.com websit. But I also use the https://www.freemaptools.com/find-zip-codes-inside-radius.htm website to determine the center zipcode.
Thank you.
Mridula
Michelle Kolak:Daniel Snyder:
Jen Claudy:
Jen Claudy:
You just changed my life! I've used RE for 18 years and didn't know you could paste into query/one of. I tried many times over the years and I could have sworn I'd asked for that functionality multiple times. l guess I never tried with scrolling down. I'm amazed! Thank you for this tidbit that will save me sooo much time in the future!
Stephanie
5 -
Hi Angela, you do not need to enter all zip codes separately. You can use "between" operator for a range of zip codes and "begins with" operator to enter single zip code in the query. When I get the list of zip codes, I separate them as a small groups or a single one. I try to take a group of zip codes as much as possible. For a single zip code, Address Processing Zip begins with 80614* and for a range of zip codes, Address Processing Zip between 80001 AND 80047*. Using the "*" sign is important. Result might include few extra people by using the zip codes as a group. But the requester can filter the file using city. Hope the information was helpful. Below is the screen shot for the cities within 20 mile radius of Denver area.:
Thank you.
MridulaCarolyn Moatz:
Jen Claudy:
Daniel Snyder:
Check out the following in the RE7 Idea Bank: Radius Search in Query (as well as Radius Search Please, posted by Angela yesterday) and Zip (which adds to an older Idea, Query Using Wildcards). There are a few others that came up with my search words of "query zip" and probably many more with other search terms. But go Vote, because that's the best way to make your voice heard about what you want to see.Thanks for the links! I voted. We have used RecordRadar since 2012 and we love it. Saves so much time and for our organization the price could not be more reasonable. So easy to change radius to see who you are missing and control which records you want to see.
Daniel Snyder:
Jen Claudy:
When you copy and paste multiple zip codes how do you account for zips with the +4?2 -
Begins With doesn't let you paste in multiple zip codes like One Of does, so it gets a bit unwieldy when you're working with dozens or hundreds of codes.3
Alan French:
This is very true, however, if you have complete or nearly-complete list of zips in a range, such as 10001 to 10099, you can use "Begins With 100" and with the OR operator, add more lines to the query. I also use Between a lot, and start with a 5 digit zip and end with the 9 digit zip (xxxxx-9999). That will account for 9 digit zip codes in that range. Regardless, I find it time-consuming to convert the online results to query, so I will take another look at RecordRadar. And I will vote!!
Microsoft MapPoint is a great software tool that I currently use in conjunction with RE query and export. For example, if I want addresses within a 60 mile radius of St. Louis, MO, I query and export all MO and IL addresses. I then easily upload them to MapPoint. In MapPoint I then drag a circle radius of 60 miles around St. Louis, MO and then MapPoint exports only those addresses to excel. There might also be other export options, but I use excel. Using MapPoint is so much more efficient than trying to determine and enter all the zip codes.
Andrea2 -
The trouble I find with this is RE misses +4 zip codes unless you end each zip code with an *. Learned that the hard way.
I love the MapPoint idea. I'm saving that one.2 -
Unfortunately MapPoint was discontinued and no longer available for purchase. We purchased it a few years ago, but I'm not sure what we will do when we need to replace it. Haven't found anything suitable especially at an affordable price (MapPoint was $15 per license through TechSoup).2
Zip+4 age-old problem fixed...well...crushed!
We just implemented an idea to fix the age-old problem with zip+4 and querying "one of" and missing records because they have a zip+4. We tested it and it works perfectly.
We setup an address attribute for the preferred zip (-4). We now use this to query zip codes in a mile radius using a free website to identify zip codes based on a mile radius. (https://www.zipcodestogo.com/lookups/radius-search.php). You can create an address attribute for the different types of address. To insert the zip (-4) into the attribute...you need to complete a load or have a team who can implement a process to automate on a schedule. If anyone is interested in learning more...I'd be happy to provide more detail.
