if then else for report text
In Crystal Reports 9 is it possible to hide or show a field label based on whether the field is empty or not? For example, depending on whether the constituent is an individual or an organization I want to print the membership category. I'm trying to avoid empty fields after the "Category:" label.
  • Try reading this forum post: http://www.crystalreportsbook.com/forum/forum_posts.asp?TID=5278. Let me know if it worked!
  • Marie Stark
    Marie Stark ✭✭✭✭✭
    Steven,
    What I do is  right click on the label and select Format Text, then click the Suppress button, then click on the formul editor button to the right of that. In the fomula editor I have the following:
     {whatever my field name is} = ' ' or isnull({whatever my field name is}}
    I hope that helps.
  • Paula Alionyte:
    Paula,
    Thanks for the link, I'll let you know how it turns out.
    Steven
  • Marie Stark:
    Steven,
    I hope that helps.
    Marie,
    Fantastic. This works for one of the fields, however, the other is a date field and the formula editor requires a date not a blank. These records won't have membership expiration dates. Is there a similar expression I can use to test them?
    Steven
  • Marie Stark
    Marie Stark ✭✭✭✭✭
    Steven,
    You could try just saying isnull({whatever date}).
    If that doesn;t work please let me know. I think I have another formula to convert the date to text.
  • Marie,
    I had a chance to give it a little more thought and the same suppression criteria is valid for both.
    Thanks for your help with this.
    Steven
