Secondary Preferred Address Field
Does anyone know if the send mail box is checked in the preferred address tab but not unchecked in the secondary address field wil mail go out ?
I don't think are department has admin right to the secondary tab not allowed to edit the secondary field.
Hi Rachel,
It depends on how you are pulling the mailing list- if you go through export, you can tell it which address to use, and it will use that address. You can have multiple addresses with "send mail" checked, but the processing will determine to which address the mail is sent. You do need to have send mail checked on the primary address for the person to be included in mailings (thank you letters, envelopes).
Lauren Henderson
Sacred Heart Academy0
