thermometer graph with reaching your goals
Does anyone know how to create a thermometer graph using Crystal Report?
  • Erica Esson:
    Ah, the dreaded thermometer chart. There isn't one natively.
    You can do a stacked bar chart, where if you're trying to show the progress of {actual} to {goal}, you set up a formula that is {@remaining}, which is basically {goal} - {actual}.
    Then you set up a stacked bar chart with sum of {actual} and {@remaining} as your summary fields. You'll have to fiddle with it but you can end up with something pretty close.
  • James Andrews:
    Thank you for your suggestion. I'm not able to summarize the formulas.
