Sorting Organization Name Unable to avoid "The"
This should be the easiest thing ever... I'm exporting a bunch of organizations into a crystal report, using Blackbaud Report Writer Database. I am using CnBio_Sort_name in order to be able to sort them properly once they get there, but once I get them to the crystal report it seems to revert to the full name: "The Red Cross", "The United Way" etc. If I change the export to an excel file, it drops the definite article like it's supposed to: "Red Cross", "United Way" Any hints? Thanks!
  • Peter Mckay:
    Try using the Sort Key instead?
  • Josh Bekerman:
    For some reason I have never found a way to do this. I do not believe SortName or SortKey work on org records at all. If critically important you may need to begin adding a sort alias so that you can use it in Crystal.
  • Marie Stark
    Marie Stark ✭✭✭✭✭
    Melissa Graves:
    I think it works only if you use a slash in the name, such as The\\ABC Company.
  • Peter Mckay:
    If you really really can't get the sortkey to export in a meaningful way, you could always test for it in a formula, like this:
    if (left ({orgname},3) = 'the')
    then mid({orgname}, 5, len({orgname})-4)
    else {orgname}
    That formula basically says, look at the first three letters of the name, and if they're "the" then skip that and give me the rest of the orgname. If not, just give me the orgname.
  • Marie Stark:
    Backslash or none - I am pretty sure sortkey and sort name are not affected. I think you need to use a formula as suggested.
  • Melissa Graves:
    I identified this a while ago and added it to the discovery uservoice site. Please add your vote to the suggestion here!
    http://rediscovery.uservoice.com/forums/137015-raiser-s-edge-discovery-topics/suggestions/3922118-change-how-sortkey-is-done-for-organizations
  • Melissa Graves:
    Thanks so much everybody. I voted for this solution, Melissa, and the if statement formula works like a charm, James. :-)
