Exporting Address Line 1, 2 etc rather than as whole Address Block
Hi Everyone
Can anyone advise where or how it is possible to select just the address lines rather than an entire address block from the SQL server?
I can see the address block in dbo.ADDRESS but can't see just the address lines in a table by itself. It is possible to split the Address Block field?
Thanks once again for your help.
Neil
Neil Hunter:
Hi Everyone
Neil
The RE database contains a 'Scaler-valued Function' called DBO.ADDRESLINES. If you create a query in Raiser's Edge and output each of the address lines, this function is referenced.
Not sure how familiar you are with the SQL Server Management Studio but you can find that function within your Raiser's Edge database stucture, under Programmability, Functions, Scaler-Valued Functions. I don't think you can reference this within certain programs (like Crystal Reports) but you can create a custom 'View' in SSMS that will segment the address lines. This is how I wrote it, we have SQL Server 2008 R2:
CREATE VIEW [dbo].[CUSTOM_ADDRESS_Preferred]
AS
SELECT
RECORDS.CONSTITUENT_ID AS 'ConstitID',
RECORDS.IMPORT_ID AS 'ImportID',
dbo.CONSTIT_ADDRESS.IMPORT_ID AS 'Address ImportID',
dbo.ADDRESSLINE(1,dbo.ADDRESS.ADDRESS_BLOCK) AS 'Address Line 1',
dbo.ADDRESSLINE(2,dbo.ADDRESS.ADDRESS_BLOCK) AS 'Address Line 2',
dbo.ADDRESSLINE(3,dbo.ADDRESS.ADDRESS_BLOCK) AS 'Address Line 3',
dbo.ADDRESS.CITY AS 'City',
dbo.ADDRESS.STATE AS 'State',
dbo.ADDRESS.POST_CODE AS 'Zip',
dbo.CONSTIT_ADDRESS.ID AS 'Address Link'FROM
dbo.RECORDS AS RECORDS INNER JOIN
dbo.CONSTIT_ADDRESS ON RECORDS.ID = dbo.CONSTIT_ADDRESS.CONSTIT_ID INNER JOIN
dbo.ADDRESS ON dbo.CONSTIT_ADDRESS.ADDRESS_ID = dbo.ADDRESS.ID LEFT OUTER JOIN
dbo.TABLEENTRIES AS MSATABLE ON dbo.ADDRESS.REGION = MSATABLE.TABLEENTRIESID LEFT OUTER JOIN
dbo.TABLEENTRIES AS ADDTYPETABLE ON dbo.CONSTIT_ADDRESS.TYPE = ADDTYPETABLE.TABLEENTRIESIDWHERE
(RECORDS.IS_CONSTITUENT = - 1) AND (dbo.CONSTIT_ADDRESS.PREFERRED = - 1)0 -
Patrick Manning:
AS
SELECT
(RECORDS.IS_CONSTITUENT = - 1) AND (dbo.CONSTIT_ADDRESS.PREFERRED = - 1)Thank you Patrick, that's exactly what I was after.
