Joining dbo.RECORDS and dbo.ADDRESS
Hi Everyone
I'm having problems with a query where I need to select information from the dbo.RECORDS table such as first name, last name etc.
I also need to select the region field from dbo.ADDRESS but can not see how these 2 tables join? I initially used the ID field in both this gives the wrong address information. Below is the query I am using and any help would be appreciated:
select
act.DTE,
t1.LONGDESCRIPTION,
rec.CONSTITUENT_ID,
rec.FIRST_NAME,
rec.LAST_NAME
from dbo.ACTIONS as act
left join dbo.RECORDS as rec on act.RECORDS_ID = rec.ID
left join dbo.ADDRESS as add1 on rec.ID = add1.ID
left join dbo.TABLEENTRIES as t2 on act.TYPE = t2.TABLEENTRIESID
left join dbo.TABLEENTRIES as t1 on add1.REGION = t1.TABLEENTRIESID
where t2.LONGDESCRIPTION = 'Helpline Enquiry'
and act.DTE between '2013-09-01 00:00:00' and '2013-09-30 23:59:59'
Many thanks
Neil
Neil Hunter:
Use CONSTIT_ADDRESS table. Here is information from Raiser's Edge db schema help file:Hi Everyone
select
act.DTE,
t1.LONGDESCRIPTION,
rec.CONSTITUENT_ID,
rec.FIRST_NAME,
rec.LAST_NAME
Many thanks
Neil
Mark Zarbailov:
Use CONSTIT_ADDRESS table. Here is information from Raiser's Edge db schema help file:Thank you Mark, that worked a treat.
