Events and the participant note feature
Hi, I am trying to write a crystal report that will pull the notes (not comments) from the participant record within the event module. Granted I am still learning crystal but I believe my issue is in the export section...I can't seem to locate how to 'export' that particular note section (not the comment line - has it has limits on characters.). Any advice or suggestions on how I can pull this into crystal would be greatly appreciated. All my best, Jeannine
  • Jeannine Lozier:
    Hi Jeannine,
    You are correct that it needs to start with the export.  Make sure you are creating a participant export.  Under output, Notes is one of the main field choices.  Make sure you are exporting the file as a "Blackbaud Report Writer Database (MDB)."  Then all of the fields you should should be available when you bring the database into Crystal Reports.
    Hope that helps.
    Shirley
