Alternate Single Sign On (SSO) method
Please read this document if you are interested in an alternate single sign on method.
http://community.customer.convio.com/docs/DOC-1739
  • Just a housekeeping note that there is a new SSO process that uses the Convio SSO APIs with Convio as master. This document is located:
    http://community.customer.convio.com/docs/DOC-2183
    and streamlines some of the steps that were necessary in the previous method.
  • Corey Pudhorodsky:
    Will the original method continue to work, or are there plans to deprecate it?
  • Robert Zakon:
    Yes, the original method will continue to work as expected but there are some big benefits of using the new method. Error handling and messages user experiance can be customized to a much greater degree with the new APIs for single sign on.
    "Remember me" does not seem to be working with SSO. We had complaints about it so I hid or remember me checkbox on our login form. Should it work, or is there something that needs to be done in order for it to work?
  • Adrian Cotter:
    I have it as a hidden field and have not had any reports of problems. (which of course doesn't mean something hasn't changed on Convio's side)
  • Robert Zakon:
    Actually, now that I think about it, it might be a combined effect of the 15 session timeout.
    What happens when the session expires. Does the site then remember you?
    So if my 15 minute session hack-around works, then maybe my complaints about this will go away as well.
