How does a user get their lost password
I'm using SSO redirect logins (which is not working - but thats a headache for another discussion)
In our former getactive solution we had a retrieve password link that worked perfectly. I've searched and searched and searched and I can't find any documentaion on what the url for the retrieve lost password link is.
Any help will be appreciated - We have 'migrated' to convio but our site is currently unusable because the API is failing us.
  • Kofi, please try this URL convention: https://{convio-hostname}/site/UserLogin. Your constituents can use the form on this page to retreive their password.
  • Stephen O:
    On a related note, I am trying to build a set of reusable login management components, such that I can embed it in any wrapper so a user can login, get a password hint, reset, etc without navigating to UserLogin and away from the page they're looking at.
    Is it at all possible to retrieve a password hint or trigger the password email reminder without using the UserLogin page? I suppose I'm probably missing something obvious in the docs, so if that's the case please point me in the right direction!
  • Greg Zelder:
    Greg,
    Call the CRConsAPI:login method with the constituent’s email address in the email parameter and send_user_name=true. A message with the user name and password will be mailed to that user’s email address.
    Steve
  • Steve Mook:
    Greg,
    Steve
    As far as I can tell, this method sends the username only. Is there something else I must do to get the username/password email?
    We've also run into another problem involving a login form which only requires last name and member ID (confusingly, though, the member ID our members input here is actually custom_number4). Using method=authenticateUser works just fine unless the constituent has an empty primary_email, which happens fairly often when we upload constituent data from Raiser's Edge. When the email is null, the entire site breaks with a servlet error saying 'primary_email cannot be empty' .
    Is this something I can work around? I've been trying without success for days here...
  • Steve Mook:
    Greg,
    Steve
    I've also been trying to get the password to be sent when I inlcude the email and "send_user_name=true" parameters to the login method, but only the username is emailed. Are there extra parameters that need to be added to get the email to include the password?
  • Chris Steipp:
    Every now and then, I'll come across a case where my test environment is configured precisely opposite our clients' production environments. I think we do this just to keep ourselves humble. It tends to happen where security and convenience diverge, as in this case.
    So, there is at present a bug in login API. To get a production site to return a password email from a call to the login, you must either contact Convio support to update a session data parameter to match the configuration we use in test, or log in to Convio, go to Setup / Autoresponders, and override the default Login / Send User Name auto-responder with the contents of the Login / Send Password auto-responder. With either work-around, new users will also be emailed thier password when they register, which is not now Convio's default behavior, and is considered less secure.
    --Steve
  • Steve Mook:
    --Steve
    Is there a way for us to check on the status of this and other bugs?
