Incorrect API Key
I set the API key in my post data as the same one as I set in the Site Options.
https://secure2.convio.net/CLIENT/site/SRConsAPI?api_key=554596D320004366A038F0DA1623A732&v=1.0&no_welcome=f&email.accepts_email=t&method=create&email.primary_address=rvuscdprxwzv%40mailinator.com
This worked fine in the test center at http://open.convio.com however its not in our .NET code.
I'm just trying to signup a user to the email list.
  • I would recommend opening a case on the support site. If it is working in test but not appearing your code, I think you should probably go over it with a technician. Hope that helps a bit!
    https://ssl.salesforce.com/sserv/login.jsp?orgId=00D000000009LHQ
  • On second thought, I went in and checked your API configuration on the Convio side. You had the CONVIO_API_IP_FILTER property set to 69.104.13.244 but it needs to include an IP and a netmask: 69.104.13.244/24
    Try that out and let me know if it works.
    Message was edited by: Bruce Keilin
  • Bruce Keilin:
    So that didn't work.
    using System;
    using System.Collections.Generic;
    using System.Linq;
    using System.Text;
    using System.Net;
    using System.IO;
    namespace TestConvio
    class Program
    static void Main(string[] args)
    Console.Write(SubscribeUserToConvio("rahul10001@mailinator.com"));
    Console.ReadKey();
    protected static string SubscribeUserToConvio(string emailAddress)
    string convioApiLocation = "https://secure2.convio.net/CLIENT/site/SRConsAPI";
    string convioApiKey = "KEY";
    string convioApiVersion = "1.0";
    string postData = "?api_key="+convioApiKey;
    postData = "&v="convioApiVersion;
    postData += "&no_welcome=f";
    postData += "&email.accepts_email=t";
    postData += "&method=create";
    postData = "&email.primary_address="emailAddress.Replace("@,%40");
    return Post(convioApiLocation, postData)+convioApiLocation + postData;
    protected static string Post(string url, string postData)
    byte[] buffer = Encoding.UTF8.GetBytes(postData);
    int bufferLength = buffer.Length;
    HttpWebRequest request = (HttpWebRequest)HttpWebRequest.Create(url);
    request.Method = "POST";
    request.ContentLength = bufferLength;
    string result;
    using (Stream requestStream = request.GetRequestStream())
    requestStream.Write(buffer, 0, bufferLength);
    try
    using (HttpWebResponse response = (HttpWebResponse)request.GetResponse())
    using (Stream responseStream = response.GetResponseStream())
    using (StreamReader readStream = new StreamReader(responseStream, Encoding.UTF8))
    result = readStream.ReadToEnd();
    catch (WebException wEx)
    using (Stream errorResponseStream = wEx.Response.GetResponseStream())
    using (StreamReader errorReadStream = new StreamReader(errorResponseStream, Encoding.UTF8))
    result = errorReadStream.ReadToEnd();
    return result;
  • johnbrian.mccarthy user_10770_lastname_invali:
    using System;
    using System.Linq;
    using System.Text;
    using System.Net;
    using System.IO;
    class Program
    Console.ReadKey();
    string result;
    try
    return result;
    I found out my correct CIDR address... 69.104.13.241/28
    Added the Convio API Admin user as this document suggests : http://customer.convio.com/site/PageServer?pagename=Help_Admin_ConvioAPIs_SiteConfig
    And retried my code with two added fields for the user name and password..
    postData += "&login_name=" + convioLoginName;
    postData += "&login_password=" + convioLoginPassword;
    Still no go.
    Rahul
    Still no go.
    Rahul
    What do you get back from your POST? Also, I'm not entirely sure you are POSTing properly. It looks like a GET query string and not exactly like POST data (e.g. you shouldn't have a leading ?. Might be worthwhile inspecting the HTTP traffic (using something like Charles) to make sure it's properly formatted.
  • For the record, the problem was that the POST was not sending the appropriate content-type header. POSTs to the Convio API must set:
    content-type=application/x-www-form-urlencoded
