The ABC's of Convio API's
We need a user friendly way to query our own database and then create a group in C360 from the result set. Often times all the data attributes required for selecting the desired population for a group will not reside in C360. Is the Constituent API robust enough to be used by an application that will need to process a large result set and create a C360 group and also update a single C360 attribute for each member of the new group?
Are you trying to do something like this:
- Perform a query in your (non-Convio) database
- Create a new group in Convio
- Iterate over each record in the set returned in step 1 and
- add the person to the new group in Cons360
- change a Cons360 attribrute for the person
I think that would work. The only problem you would have is if the first query was against Cons360 (not your own DB) and the result set is very large (> 1000 records, I think.)
Hope that helps.
