Single Sign On Using Convio as Master
Detailed documentation, including functioning examples, of implementing the Single Sign On protocol using Convio as the master.
  • Are there any working examples? I can understand the system a lot better with working examples.
  • What would you need in addition to the samples in the document, which are working code? If you can elaborate on what you would need, that is, give me a clearer sense of what you want beyond those samples, I'm sure I can find someone to provide what you need.
