Donation API
Hello everyone,
I followed the example that Dave has in "Donation API Seminar.ppt"(http://community.customer.convio.com/docs/DOC-2025) and created a donation form(https://secure2.convio.net/holt/site/Donation2?1700.donation=form1&df_id=1700). Then created 3 pages:
https://secure2.convio.net/holt/site/SPageServer?pagename=donation_success
I can't get it to work. Even if I have Javascript on, it still goes to the error page. Am I missing something? All input is appreciated.
The problem is that, since you've made the donation level a hidden input rather than prompting the user to choose a gift amount, validateForm() is invalid and causes the whole thing to fail (since "level_other" and "other_amount" don't exist). Remove that function and change:
if (validateForm()) {
// Tell the user that donation is processing
displayAjaxLoading(true, 'Please wait while your transaction is being processed.');
// Make the AJAX call
var url = donate_form.action;
var args = getFormAsQuery(donate_form);
var myAjax = new Ajax.Request( url,
method: 'post',
parameters: args,
onSuccess: handleAjaxSuccess,
onFailure: handleAjaxFailure,
onException: handleAjaxFailure
}... to:
method: 'post',
parameters: args,
Once you do that, the AJAX form submission should work.0 -
Noah Cooper:
method: 'post',
parameters: args,
}... to:
method: 'post',
parameters: args,
Once you do that, the AJAX form submission should work.Thank you very much for your qick answer Noah
I did what you recommended and now it will display error message only on the CC field. When I filled out everything on the form(CC# 4111111111111111), it did not process.
Hai Nguyen:
Forms have to be published to work with the Donation API and the test credit card number will not work on published form. You'll have to test with a live, real, credit card. I usually use my own, then refund it right away... it's a pain in the neck, but... c'est la vie!
Michael :
Michael, look like I have to do the same. Also, it seems like the error message only work for the CC field. https://secure.oxfamamerica.org/site/SPageNavigator/donate_form_monthly_option?pagename=donate_formThanks0
