Can Donation API capture subsrc codes??
Hello guys,
I had a quick question regarding the donation API process.
We currently have a donation form set up on our site using the API and I was wondering how we can get this form to recongnize subsrc codes in the url. Is the only option currently to hardcode this code into a hidden input field?
Matt
If the page is hosted in PageBuilder, you can use ] to render the value of a passed-in subsrc parameter in the page url in the value attribute of a hidden input in the form.
Steve Mook:
Steve,
Thanks... I will try this and see if this works for me.
Let me know. I tried a couple different URLs:
http://bvt318.convio.com/site/PageServer?pagename=MyDonationForm&subsrc=testing12345
http://bvt318.convio.com/site/PageServer?pagename=MyDonationForm&subsrc=54321testand these worked successfully to add constituents with different Origin sub-source codes using the following hidden inputs in the Donation form:
<input type="hidden" name="source" id="source" value="mydonationform" />
<input type="hidden" name="sub_source" id="subsrc" value="]" />0 -
Steve Mook:
<input type="hidden" name="sub_source" id="subsrc" value="]" />One thing I'd note -- if you want sub-source to be carried over to pages the constituent visits in the session other than the donation form, you should use the query string s_subsrc, and thus ].
