Survey Code Snippet
Hi,
How do I create a code snippet for a survey that can be embedded in an external website? We were given snippets of code for donation forms as a part of our Convio Go! program and I would like to have something similar for newsletter sign-ups, if that's possible...
Christy R.
Christy,
Here's a post I did with several code snippets for registration forms using the Survey tool.
Since you would be putting this on a non-Luminate page, just make sure you use absolute URLs. That means don't use ".../survey/ID....." but use "http://XYZorg.org/survey/ID.....".
Let me know if you need any help. I know that since you are a Go! client you should have a number of snippets. You should be able to use one of these as well. Just copy the code and put it wherever you want. If you want to use a different form for this registration opportunity you will simply need to change the Survey ID to be that of your new Survey.
Hope this helps!
Kent
Thank you, Ken! This is MOST helpful! Christy Richardson Web Coordinator Foundations for Laity Renewal Founded by the H. E. Butt Foundation 830.792.7567 crichardson@laityrenewal.org0
Kent,
I'm interested in creating a email signup snippet tied to a specific, targeted survey. We have some generic snippet code created for us through the GO program. It sounds like the post you referenced here might be of help to us, but the link is broken. Can you help me find that particular post? Thanks!
Amy0 -
Amy, check this thread for some helpful resources and examples.0
