Removing automatic Text from an Event Page
Is there a way to remove the text, "This event does not require an RSVP. Registered users can request event reminders. Register.” (with a link to register for an account at our site) from certain event pages?
The only way to do this is to use some JavaScript to hide it. I'm viewing this on my phone but I think this is the link that will give you what you need. http://community.convio.com/t5/Luminate-Online/Event-page-questions/m-p/13054/highlight/true#M60580
Kent Gilliam:
The only way to do this is to use some JavaScript to hide it. I'm viewing this on my phone but I think this is the link that will give you what you need. http://community.convio.com/t5/Luminate-Online/Event-page-questions/m-p/13054/highlight/true#M6058Hi Kent
This leads to a 404 error page (like many posts). Is there documentation on how to remove this text somewhere else?
Thanks for any direction you can offer.
Miranda
Miranda Yorke:
Kent Gilliam:
MirandaMiranda - the link Kent put in above is now here: https://community.blackbaud.com/forums/viewtopic/1/2288?post_id=19346#p19346
(FYI - luckily the name of the post is reflected in the url from the old community, so you can usually still find them by searching by the name - in this case, the post is called "Event page questions.")
When you need to hide something on a page, it might also help to right-click it and "inspect element" to see if it has a specific ID - if it does, it should be as simple as this jquery script we use in the "Event Description" HTML box to hide the "Return to calendar" link:
$('#lo-UserDetailInfoOtherInfo').hide();
Just pop the appropriate element ID in there instead.
Hope that info helps!
