Curl command in Automic
Is anyone using a curl shell script that is run in Automic? My curl works fine and pulls the csv file from AW but in Automic it is only in the log file.
@darcelle cowles - I've never used CURL in Atomic…except in a Bash Script called from Atomic.
In that script I designate WHERE I want the output file to go for example
curl --verbose -g -o "\\\\aiken\\ProdITFileTrans\\csas_file01.txt" "https://bigschool.com/api/v1/disbursements.csv?c[]=initial_application_category_name__contains__Offered&c[]=opportunity_archived__eq__0&c[]=award_period_name__contains__2425&page=1&per_page=1000&fields=award_period_name,user_uid,portfolio_code,disbursement_amount,initial_application_category_id,id,award_period_id,form_field_10473&token=OURTOKENKEY"
If I call the script that has this from Atomic … the output goes to the file name and directory I designated "\\\\aiken\\ProdITFileTrans\\csas_file01.txt" which is a network drive0
- 361 Blackbaud eTapestry®
- JustGiving® from Blackbaud®
- 262 ResearchPoint™
