Query in NXT question
when I run a query in database I set up the criteria and then go to the EXPORT module to actually pull the list. EXPORT allows me to pull the constituent with multiple emails or gifts in one row as apposed to query that will create multiple rows for one constituent. How do I do that EXPORT in webview. It is not the export tab within query. EXPORT in a separate module in database.
@Amanda Schlehuber that is correct. For the time being, you would create the query in web view and use the same Export module in database view.
3 -
@Amanda Schlehuber RE Export Module is not in RE NXT at this time, so you need to do what John stated.
- 361 Blackbaud eTapestry®
- JustGiving® from Blackbaud®
- 262 ResearchPoint™
